2nd Gen Non-Engine/Transmission DSS track bar and Maghytec cover??
2nd Gen Non-Engine/Transmission New truck needs 6 tires ????
Engine/Transmission (1998.5 - 2002) Hx35/40 compaired to a 62/65/12
Just a quick shout—planning to go to DSS bracket and 3rd gen TB, any known interference with new TB and Maghytec front cover for the Dana 60 front axles?? Thanks in advance.
I have the same set up and no lift. Only thing I wish I spotted early was the possiblity that the bracket for my steering stablizer shock would contact the cover when full left turn. Just barely nicked my cover but surely voided the warranty. Otherwise it all works well.
Chuck
Chuck
Ditto here,
I have the same setup with a 2" leveling kit. I clearanced the stabilizer bracket during install. Also, make sure the tie rod adjustment sleeve bolts are positioned properly so they will clear the cover as you steer.
Dave
Yeah, I thought I had confirmed clearance during install but it's hard to get full travel even with the front axle up on jacks and turn the wheel with the truck running. I did it when I was also bleeding my ps pump. I think you can get just a bit more travel driving normally, for example, driving over a curb full lock to the left. Either way I just needed to grind off the corner of the bracket to solve the problem.
