starring said:After following all of the contraversy am i safe to assume that i will have very few problems installing the dt track bar on a truck with stock suspension, and slightly oversized tires?
EBottema said:... . Welding the bracket would also make this problem go away but it would cause the frame/crossmember to be heated up which could weaken it. ...
Mark_Kendrick said:The crossmember is welded together. welding around a sleeve isn't going to hurt anything. If welded properly the weld will be stronger than the original member.
FWIW,
Mark
FWIW,
Mark
EBottema said:I had the teacher who has taught for 29 years, is a certified welder and state cert. building instructor and a one of the best suspension specialists and fabricators in all of Los Angeles county
EBottema said:recommend not welding because the heat weakens the metal on the frame and could cause future cracking in the frame- not the weld,
FWIW,
Mark
EBottema said:Best way is improve the bracket and make tigther sleeves in my opinion
