Was checking front end components as an assistant moved the wheel back and forth when I noticed that the track bar was moving back and forth at the axle. I used the factory bolt per the DT instructions. The i. d. of the sleeve is larger than the o. d. of the bolt. This is where the movement is occurring. I torqued the bolt to the factory specs and then some. Has anyone else experienced this? Anyone have any ideas?
Thanks,
Bryan
Thanks,
Bryan
