would someone please tell me how a K&N filter could possibly cause an EGR Valve to stick???? This thread is soooooo far off the problem I can't believe it.
To answer your question,and to not slam the K&N air filters, Its not so much the air filter itself that causing the EGR valve to stick. As I'm sure that we all know by now that the issues that cause the EGR valve to stick is the soot in the exhaust gases that contaminates the valve faces and shaft inside the EGR valve.
What I have found is that the oil in the aftermarket air filters actualy get on the MAF sensor and coat it with a film of oil and inturn cause the MAF sensor to return inaccurate voltage signals to the ECM. This voltage signal is interpreted by the ECM to determine the Mass of air that is coming into the engine. It uses this information to determine how much EGR gases it needs to inject in the intake air stream to control the combustion temperature in the piston cylinder to reduce NOx gases in the exhaust system.
Without getting into a discussion about how a MAF sensor works, suffice to say that the oil coating the MAF sensor is causing the MAF sensor to return a voltage signal to the ECM that there is more air coming into the intake system than actually is. So inturn the ECM adds more EGR gas to the intake air than is actually nessasary, which inturn causes more soot in the exhaust gases which creates all kinds of problems.
As far as a repair goes, if you were to pull the MAF sensor out and clean it, it would be good until it gets coated again. I have been unable to determine if the problem is because the owners are adding too much oil to the air filter when they clean them or if it is just the filter itself letting the oil get into the system.
I'm not going to get into the debate as to weather the aftermarket air filters are any better than the OEM air filters, Being a dealer technician I personally recommend a OEM air filter, weather it be a MOPAR filter or a FLEETGUARD filter.
Mike
