2nd Gen Non-Engine/Transmission dtr's
Engine/Transmission (1994 - 1998) Fifth gear diagnosis
Engine/Transmission (1994 - 1998) fuel pressure gauge ?
I have a canadian model ram with the daytime running lights and the fuse blew and when replaced they stay on all the time even with key off? any suggestions :confused:
check the emergency brake pedal, there is a switch in there that controls the day time running lights, when you engage the E-Brake the day time runnings will turn off, not sure if thats the problem but it's a start
also check the relay, that could be the cause also
Scott
If the DRL module is the same as a '97 try this. Unplug the module. It is located on the driver side fender well about a foot from the firewall. This will turn off the headlights. The DRL module is what has failed and a new one is about $100. 00 from the dealer. The patch, which has done just fine on my '97 for over a year involves placing a jumper wire on the vehicle side of the plug that you just un-plugged from the DRL module. I'm not smart enough to attach pictures to this post. If you will send me your Email address I will Email the pictures I took when I figured it out.
Brad -- email address removed --
