Background: 99 2500HD 4x4 auto. 200,831 miles. About 5 years ago put DTT filter on to eliminate the transmission hunting around 40mph. This had cured the problem until the last month and now it is hunting around 60 mph. While reading recent questions and doing searches for the problem I have run across two different methods of possibly curing my problem and need some help sorting this out.
1. Was the DTT filter only good for the 40 mph problem and not for the 50+ mph problem?
2. In a post in 2006 the thread talks about a cure from ATS Diesel that involves "tapping" the ground wire from the APPS plus cutting the signal from the ECM to the PCM and rerouting.
3. Also, in the 2006 thread a filter from Happibox.com is mentioned as curing the problem with noise to the PCM.
4. In the recent thread "Locking/Unlocking" the Suncoast method of cutting only the ground wire and regrounding is used.
Questions:
1. Who has experience with the above methods (ATS vs Suncoast) and is one better than the other?
2. Can the DTT filter go bad? If so what would the symptoms be? Was it only good for the 40 mph problem?
3. If you used the Suncoast method did you have a DTT filter? This filter ties in on the same wire that the rerouted signal from the APPS ties into. Did you install the DTT on the rerouted signal?
4. Does anyone have any experience with the Happi box?
Thanks for any help
Mike
Questions:
Thanks for any help
Mike
