DTT valve body
Trany Options.
Trans temp sender - which line does it go into?
How difficult is it to install a DTT valve body? Not being to mechanically inclined. I eventually want to get the complete upgrade including the Torque Converter but $$ is the issue now. Also, will just getting the valve body make a noticeable difference in transmission performance? Thanks for any input.
Scott
VB Install
I just installed my DTT VB and it was not hard to do. The instructions included are very good and more help is only a phone call away as Bill and crew provide great customer support.
As I said, I have just the VB for now. The shifts are firm and makes the truck much more fun to drive, especially with a PE comp.
Good Luck
You won't be sorry
Tom
If your mechanically inclined it isnt to difficult,you keep everything super clean,and carefully torque the VB bolts,not overtorque,this can warp the BV or pull threads from the case. The only problems i can forsee is if it needs fine tuning.
towing
I got the towing VB. I do not race the truck like some others do but I do tow a 30' TT. btw, the towing VB makes it real fun on the street when empty. If you tow livestock, I understand the shifts are not quite so hard so it doesn't knock the animals off their feet (or hoofs).
