John,
Thanks for the advice, I'd certainly would consider going with more batteries, but I'm not looking to add that much additional weight to the RV side, If get this Dual Alternator set up going, I'd like to add one or two house batteries under the bed of the truck, where weight is far less a concern, that is where I'd get a bigger bank. That said, I've increased load via HW heater, baseboard heater, electric heaters, and fridge up to just under the 3000W, and the inverter holds it, but granted, I'd not be keeping it there for long. Voltage does drop to around 11 under heavy load. I separated the converter/charger and added a second 30A to the original 55A, this allows me to run the small generator to help the batteries with the inverter for short duration loads.
