Ok, so here is my attempt at a summary, first part, recap on parts needed:
(to be updated and corrected as needed)
PARTS LIST FOR DUAL ALTERNATOR INSTALL:
Alternator Bracket (XF7): MOPAR #: 04627793AA $ 59.72 (Moparpartsoverstock.com)
Alternator bolts (M10X1.5X105mm) (qty 2): MOPAR#: #: 06506337AA $3.20 (Moparpartsoverstock.com)
Bracket upper bolts (to engine block) (qty 3): $3 M-10 X 1.5 X 25 or 30 mm long (Lowes)
M-10 Washers (Qty 3): $0.50 (Lowes)
Bracket lower bolts (qty 2) (to fuel pump): M-8 X 1.25 X 40 to 50 mm long: $2 (Lowes)
M-8 Washers (Qty 2) $0.50 (Lowes)
Left Fan shroud Bracket: MOPAR# 68160116AA $64.70 (Moparpartsoverstock.com)
Mounting bolts (qty 2): M-8 X 1.25 X 50 mm long: $2 (Lowes)
M-8 Washers (Bag, QTY 20, use as needed to obtain correct fan shroud bracket fit): $2 (Lowes)
M-8 Nut, M-8 washer (or re-use existing, I needed one as I found one missing): $1.50 (Lowes)
Serpentine Belt MOPAR#: 04627589AA Gates #: K081298HD $ 28.79 (closeout deal) (Rock Auto)
Alternator, MOPAR #: 56029707AB, 56029707AA (About $400 new) Remy #: 11015 $129.79 + $ 50 Core ($179.79) (Rock Auto)
Bracket, Radiator hose: MOPAR# 68195735AA $6.58 (Moparpartsoverstock.com)
Electrical:
Alternator connector (2 pin): AIRTEX/WELLS# 1P1830 $12.50 (Rock Auto)
Alternator/Battery/Fusible link wire: OEM (68145075AB) $56 for*
*( I made my own: In-line 250Amp ANL fuse holder: $13.85 or you can use a 250A manual reset circuit breaker ($10) (Amazon.com) )
Dorman 85684 Conduct Tite GM Alternator Wire Boot: $6.13 (Amazon.com)
ABN Marine Battery Cable & Tinned Lug 1’ Foot in Red, 3/8" Inch Stud, 4-Gauge: $7.99 (Amazon.com)
Driver card:
VN7004CLH evaluation board high side driver board ($4.47 ea only one needed) (digikey.com)
Aluminum DIY project box $ 10 (Amazon.com)
15 Amp Diodes (pack of 20, only need 3) $7 (Amazon.com)
Wiring accessories:
Striveday Flexible Silicone Hook Up Wire 18awg $19 (Amazon.com)
Waterproof Cable Glands (pack of 30, need only ONE) $10 (Amazon.com)
Various Wire loom/protector 1/4", 3/8”, 1/2” $25 (Amazon.com)
Connectors Waterproof (3 pair) E-Ting 10 kit 2 pin Way waterproof elec plug. $12 (Amazon.com)
Optional:
4PDT on/on Switch $8 (Amazon.com)
DPDT on/on Switch $7 (Amazon.com)
Qty 2- 400A Mini Current/Volt meter with Hall Effect Sensor Transformer $48 ($24 ea) (Amazon.com)
Tools:
Serpentine Belt tool Kit: Gearwrench 3680 $41 (Amazon.com)
Serpentine Belt grabber tool: ATD Tools 8604 $22 (Amazon.com)
Electrical:
Driver card:
Wiring accessories:
Optional:
Tools:
