Dually Air
Dana 80 Limited Slip Upgrades?
Wiring for DiPricol Transmission Gage
What's a good setup for airing up the inside tire on the dually? Is there an extension, that makes this easier, and doesn't leak???
There are quite a few extenders. Mine are braided steel I bought at Camping World. The thing is, you need to change your valve stems to all metal ones or the extenders will constantly wiggle them back and forth and cause the rubber ones to fail.
Okay... I'll have them changed to metal... . I was at camping world, but they had about 5 different types of extenders in different sizes. Just wondered what type to get and what length... ;)
Mine are about 6 inches long and clamp on to the outer wheel. Kind of a ***** to install the knurl nut on the inside valve stem unless you have small hands. But if you have the outers off anyway for the metal valve stems, then that is a good time to do that part of the install. They have worked well for the last 250k
