2nd Gen Non-Engine/Transmission Dually Bed Falling Apart
2nd Gen Non-Engine/Transmission identifying rear end ratio
2nd Gen Non-Engine/Transmission Brake Fade
well my dually bed is falling apart on the driver side the hips are fine its the weld in the back on the drivers side under the tailgate i know that a good body shop can fix this but i was just wondering if any of you other dually owners has had this problem just wondering thanks
Same problem here
I had the same problem on my 96 3500 due to prior tailgate issues. I was going to weld to but I think that the heat cycle would possibly make it weaker. So instead I just used a piece of 3/4 angle aluminum verticlly. Drilled holes staggered from bed bottem to bed side. You can nut and bolt it easily, just remove the tail light assy. 5/16 fine bolts with flatwashers and nylocks. Would be glad to take pics and sendto you. Hope this helps.
Eric
