Dually factory tire size question
Waranty
Guages in Auto truck
For model years 2000 and 2001, the factory has stepped up to the LT235/85R16 tire which has really added to the stability when carrying big slide-ins (the tires now stick out beyond the fenders).
My surfing buddy has a 99 3500 with the smaller LT215/85R16's. Can somebody please explain what the factory has done to allow for the larger tire size on the newer trucks(have they lengthen the rear axle, put a shim between the wheels, etc. ). He is interested in adding the larger tires but as he totes a Bigfoot 3000, he does not want the larger tires to rub the inside sidewalls on the duallies. Is this possible??? Thanks in advance. #ad
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Leather, Sliding Rear Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine oil temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec Differential Cover, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper.
David
The reason they can put 235's on the new trucks is they changed the offset of the
wheels. I have 235's on my 99 & they work just fine. Just be careful what brand of tire
you use because even though they are the same size the cross section width vary as
much as 1. 5 in.
hope this helps
Rick
99 3500 4x4 QC,5spd,3. 55 posi,turn over ball goose neck hitch,Putnam class V reciever hitch,Alcoa alum. wheels,275 hp inj. home built boost module,4 in. straight exhaust(built it in my shop)Pac brake,4 leaf overload springs,all options execpt leather & keyless entry,2000 Artic Fox 10 ft. camper,with slide out 2horse tongue pull trlr. ,30 ft. gooseneck 3 horse living quarter trlr. ,24 ft flat bed that I haul my Ford 4x4 race truck on.
David, Rick is right, they just changed the offset to allow for the wider tires. The rim width stayed the same. I'm running Michelin 235-85's A/T,s and they work real good. Regards Pete
99'3500,quad cab,4X4,a/t
3:54,all the right packages!PROPER VALVEMENT
Thanks guys for the quick replies. I didn't realize that we were running different rims here.
[This message has been edited by dresslered (edited 10-17-2000). ]
