For model years 2000 and 2001, the factory has stepped up to the LT235/85R16 tire which has really added to the stability when carrying big slide-ins (the tires now stick out beyond the fenders).
My surfing buddy has a 99 3500 with the smaller LT215/85R16's. Can somebody please explain what the factory has done to allow for the larger tire size on the newer trucks(have they lengthen the rear axle, put a shim between the wheels, etc. ). He is interested in adding the larger tires but as he totes a Bigfoot 3000, he does not want the larger tires to rub the inside sidewalls on the duallies. Is this possible??? Thanks in advance.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Leather, Sliding Rear Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine oil temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec Differential Cover, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper.
David Dressler
