Dually fender removal procedure?
Towed a Big Rig
Thoughts on trading for a 3rd gen?
Hey all, someone decided to back into the side of my truck a few days ago, and I'll need to remove the right side dually fender to get inside it to repair the fiberglass. I'm just wondering if anyone has a procedure for removing the fender. I can't seem to find anything about it in the service manuals.
-Daniel
REMOVAL
1. Disconnect and isolate the negative battery cable.
2. Remove the tail lamp unit (Refer to 08 - Electrical/8L - Lamps and Lighting/Lamps/Lighting - Exterior/LAMP, Tail Stop Turn - Removal) .
3. Remove the rear wheelhouse splash shield. (Refer to 23 - Body/Exterior/SHIELD, Splash - Removal) .
4. Remove the two marker lamp units from the rear fender (Refer to 08 - Electrical/8L - Lamps and Lighting/Lamps/Lighting - Exterior/LAMP, Side Marker - Removal) .
5. Remove the two nuts (2) that secure the rear fender to the cargo box near the tail lamp opening (1).
6. Raise and support the vehicle.
7. Remove the two nuts (1) that secure the rear fender to the rear of the cargo box inner panel (2).
8. Remove the four bolts that secure the bottom edges of the rear fender to the cargo box.
9. Remove the four nuts (2) secure the front of the rear fender to the cargo box inner panel (1)
10. Loosen the three bolts (3) on each of the two fender support brackets (1) located on the cargo box outer panel (2).
CAUTION: Prior to removing the rear fenders, mask off the surrounding cargo box areas to avoid damage to the cargo box painted surfaces.
11. Lift the rear fender straight up and off of the two support brackets and remove the fender.
