First of all, what is a pintle hitch? You may not need a DRW, however the dually will give you a considerable amount more stability and payload capacity. Braking should be the same.
Welcome to TDR. You should include your signature.
I am looking to purchase a new truck which I will use for pulling a 12,000 lb
pintle hitch trailer. What are the pros and cons for each. I notice only a slightly smaller max towing capacity on SRW but what about braking and stability?![]()
Buy what you like. If you need training wheels, get them. You won't need them. Nobody did until Chevy came out with them in the 70's. I'll go 27-28k combined on SRW, no problem. Its whats your comfortable with.![]()
You might be surprised to learn that duallys corner better on fast curves on mountain roads because of their greater rear wheel traction.
