I just heard that Hankook make an E rated replacement for about $300. 00 less per set than the Mastercraft.
Mark
$550 for a set of six? I get the MasterCraft for $850 a set with lifetime rotation and balance.
Mark
Mine have 39K on them. The outside wheels in the rear are down to the wear bars. The inner rear and fronts look like they both have the same amount of tread on them. I am thinking of rotating the fronts to the outside rear and then replacing the steers. Should be able to get another 15K out of the other four before I have to replace them too.
For whatever it's worth, if you look at your owners guide, it says to rotate the front tires with the inside rear tires only. It may just be a valve stem difference.
If I remember correctly, the manual says to rotate the fronts with the inside duals, and swap the outsides left/right. No need to break anything down.
That's exactly what I did when I rotated mine. Then I took the never used spare, and put it on the left front, which I documented on my maintenance log book. Next time I rotate, I'll put the spare on the right front. After that, I'll need 6 new tires and I'll keep the best original for a spare.
I've never unmounted a tire fo a rotation. Are you guys doing that for OWL's or something?
Yes, I saw the owners manual shows inside rear to front on the same side which would allow the outside to constantly wear more. I have only been rotating mine side to side in the back only to keep the outside from wearing too fast.
I think whatever works for you is okay as long as you document what you did so that the next time you rotate, you'll know what you did before. Rotating 6 or 7 tires is alway more challenging then rotating 4 or 5.
