I just got off the phone with Cummins and they said the part number is 3935878 and the cost is 49. 47.
Something is wrong. I called Cummins today and they gave me the following information:
Valve cover (part 11 in above diagram): 3954324 @ $36. 15
Rocker box (part 10): 3963379 @ $10. 97
They looked this up using my engine serial number, which is 57018950.
If you put in 3963379
here, you find the description seems correct (rocker lever housing cover gasket).
Checking with
Cummins Quickserve, however, 3963379 doesn't come up with anything. Neither does 3935878.
If you search on Quickserve for the rocker box gasket, you find the assembly no problem, but it's not properly broken down into part numbers.
I find it pretty disappointing that Cummins' parts ordering isn't better than this.
If you go to one of the online Dodge parts houses, you can find the rocker box gasket (DC p/n 5101851AA) easily at a cost of about $12, which is consistent with what Cummins quoted me.
I know for certain the valve cover gasket number 3954324 is right (verified in Quickserve and at Geno's, who sells it for $31. xx).
Brian, the local Cummins shop said they have 2 of the rocker gaskets in stock. If you need me to get you the "other one" while I'm there and mail it to you, PM me.
Ryan
