Easy there, I am looking for opinions; however, an opinion in this case should also have some reasoning behind it. On that note, when I compared the Jayco to the Dutchmen, here is what I liked/ disliked:
Jayco dislikes:
fiberfill insulation, curtains (or not much more than) doors between the frojnt and rear rooms and the main area, stove (looked much less quality than in others), wood construction for sidewalls, frame- smaller and lighter than most others, 18 inch centers for all beams, regular plywood (not exterior), tubular frame (I hear trapped water and rust), small wastewater tanks, flimsy dinette legs.
Jayco likes:
Reputation, floorplans, cabinetry (full roller glides), windows (open fully), higher cargo capacity
Dutchmen likes:
foam core insulation, welded aluminum structure, real doors throughout, floorplan (very roomy with two bathrooms), steel I beam frame, 5 inch roof trusses (aluminum), 16" centers for all beams, exterior grade plywood, large holding tanks.
Dutchmen dislikes:
Reputation, cabinents (looked nice but had nylon guides).
Both models are equally priced and the warranties are the same. What else should I be comparing? They both have rack and pinion slides, are about the same length.
Any further opinions, with reason would be a great help. Thanks to all who have replied so far.
