HLewallen,
But I digress. The issue is DW and DW probably isn't going to be cured by adjusting your caster. Caster gives your truck stability and return-to-center. It also affects several other geometric properties of steering. But I wouldn't focus on this to solve your problem.
A lot has been said about running E-rated tires. As we've learned, the E-rating is a measurement of sidewall strength/flex and not simply load rating. An E-rated tire has a stiffer, less compliant sidewall than a D-rated tire.
We know that some trucks DW because of bad components. This explains why some trucks DW from the showroom. We also know that some trucks DW because of bad tires - "switched to Hummer takeoffs and now I've got DW. " In addition, proper tires mask the effects of bad components and proper components mask the effects of bad tires. This explains why some trucks never DW, even with D-rated tires.
So far, nobody has explained precisely why the tire with the weak sidewall can cause DW. We just know from experience that that switching to a better tire can cure it.
Now I'm going to totally geek out:
As your suspension moves up and down (lifted, long travel, or stock) your toe changes. You get an increase (positive) on the down stroke and a decrease (negative) on the up stroke. That's just how your suspension works. A stiff sidewall with a narrow contact patch (OE tire) or the Rickson 19. 5 set up is inherently anti-DW because, even in a high traction situation on pavement, the tread is permitted to rotate slightly around its axis as toe changes during normal suspension cycling. Now, switch to a larger contact patch - the number 315 comes to mind - that's width in millimeters - and a weaker sidewall - the letter "D" comes to mind - that's "ply rating. " Anyway, now you're increasing traction while simultaneously decreasing sidewall stiffness. The result is that instead of transmitting the rotational forces of toe change to the tread, the tread stays planted under 4660 lbs. (front axle - 3rd Gen. ) of diesel beast and every bit of that rotational force gets distributed into the sidewall of the tire. Next you get a harmonic that develops in the sidewall that spreads into your steering and throughout the entire vehicle - DW. Interestingly, it's nearly impossible to get sidewall-induced DW while off-road in low traction situations. The low friction coefficient of good old dirt permits the tread to rotate, so the sidewall doesn't have to bear the brunt of toe change.
Here's the point to all this: As you go up in tire size, your contact patch increases. Correspondingly your traction increases thereby necessitating an even stiffer sidewall to transmit normal suspension and steering movements to the ground where they can be dissipated harmlessly instead of into your vehicle where the effects are manifest as DW.
Combine this tire phenomenon with a loose tie rod end or sloppy drag link and you get a pretty scary truck - a truck even scarier than Boardman's off-road driving.
That's what we know so far.
Best Regards,
Kent Kroeker
