brods said:
Are you familiar with those other kits? Looks like they might use a custom spindle and off the shelf dana 60 parts for the rest of the kit?
ACoffel, thanks for the pictures, do you have one from the front showing how far the lockouts stick out past the tire? It looks pretty good with the hub cap over it.
Stopping 3 ujoints, 1 cv joint, 1 slip joint, 4 seals and the gears from rotating (and wearing) all the time, plus eliminating the 70 mph resonance are tempting reasons to buy the kit. Also, if a front ujoint goes bad, being able to drive the truck indefinitely, without fear of the joint failing and taking out the shafts, is another benefit. Any mpg gain is a bonus.
I am not familiar with the other two companies and have no reason to doubt their quality being on par with Dynatrac, but I would advise anyone considering them to do the research and make sure they are not using imported components.
I will try and get a frontal pic of the truck posted soon so that you can see
the amount of hub protrusion. They stick out enough that many people would
probably find them a detraction , but with the cap installed I think they look o. k. I'm a "function before form" kind of guy so I don't get to concerned with
cosmetics, but the wife thought the hubs looked tacky when I first got them
on so I put the caps on to keep her happy since she does help me keep
Chrysler Financial happy.
As you pointed out , there are several benefits to the install , but I just don't
like the antiquated full time arrangement . The only reason we get full time
unit bearing front axles from DC ( and every other manufacturer for that matter) is that it saves them money in assembly time and components and appeases the masses of LAZY folks who don't want to have to get out of the
vehicle to engage the axle. I personally would rather get out and lock the hubs on the rare occasion that I need 4wd than to replace u-joints on a
regular basis.
