Dynatrac Pro 60 Stub-Hub Conversion Kit
ATS Manifold install
fass pump help! diesel dan
Looks like combining this kit with the dynatrac freespin hub conversion could solve the problem with the current version of hub sticking out a foot on each side.
i haven't called them yet but it looks promising.
i sure hope it's what i think it is. take a look.
jeff
Good question. Looks like they need to do something. They stick way out there on a SRW truck.
Wouldn't be a problem on a dually, since we have an extension for dually rims.
Thanks to a siezed u joint, I'm looking at free wheeling while I have the front end apart. Is Dynatrac the only one making a converstion kit for the 2004 Dodge?
Thanks,
Dave
Installed the EMS kit, they do stick out, about 4 inchs more than stock
hub cap, The inner and outter bearings have more seperation than OEM,
steers better...
SO FAR, 3k miles, Very satisified... .
Can use low range for moving truck camper in tight and steep places without
the drive train binding,
Also I believe an increase in MPG need to re calcuate my mpg from the last trip,
AND, REAL GREESEABLE BEARINGS. .
i've had no luck verifying if any short hub kit will work with the AAM's from dynatrac or ems. i'm not doing this conversion unless there's a shorter version. any one know if this works yet?
jeff
measured the differance from stock hub cap,
2 1/4 inches is how far the
EMS Warn Hub sticks out compared to stock hubcap.
On a dually do they stick out past the hubcap since there is a spacer on the front axle (between the rim and axle)?
