Dyno Graphs - Not just numbers
Bad place for reverse?
AHH .....NO OIL PRESSURE!!! what do I do now?
I am curious as to what other graphs look like. So if you have a dyno graph of your truck and have it available digitally please post here if you don't mind sharing. I would suggest "linking" to it to be modem user friendly. If you can't link to it let me know and I can probably provide a link.
I'll start things off... here is mine, the mods are listed in the signature.
Oct 14 2001 Dynojet
Thank you
Two from a friends truck
Here are two from a friends truck.
2001. 5 ETH
QC, LB, 4x4
3. 54, 265/75R
Edge EZ, middle setting
Bosch 275 RV Injectors
BHAF
1st run was in 5th
2nd run in 6th
DynoJet Dyno had trouble loading the engine, truck never saw more that 30lbs of boost. Truck can make 36lbs empty climbing a good hill.
Dyno 1
Dyno 2
Dave
Re: Two from a friends truck
Originally posted by Dave D
1st run was in 5th
2nd run in 6th
Thanks for brining up an excellant point, also when the graphs are posted please post what dyno, and what method was used.
Mine was in Overdrive with the TC locked up on my auto. We had to feather the throttle to get it into overdrive and lock up and then roll into it to keep it locked.
I've got the one from our Houston Dyno Day. This was on a Dynojet machine. We did twwo pulls in 4th gear(1:1). This was with the Stock plate slid forward and a K&N filter only. Haven't dynoed with the new mods yet. Gotta get a clutch in order to put it to the ground.
Dyno Run
Ok, I just scanned it in. I don't know if it will upload properly due to it's size, but here goes.
Ok, it's still too big, so I'll have to post it on my web site tomorrow from work and then add the URL.
Tom
