Dyno Numbers with Smarty...
Oil Pressure Gauge
Banks PowerPDA/Six-Gun and timing...
Was hoping for 600 but ran a little short.
The best run was with just the SMARTY on 9 and the TS box on about 20%.
We turned the TST on and started to lose a little power but it kept up the power in the later rpm's. . (good info!). The 2nd run was with the TST box on level 2x1.
This was with 12psi fuel pressure :-laf
THANKS DAVID AND COMPANY FOR THE OUTSTANDING WORK ON THE DYNO AS ALWAYS!! :D
you need about 45psi of fuel pressure @ the cp3 to get the power your looking for. also the stack of timing and duration boxes are very limited to power production, and can be very dangerous--650 hp is the most i've heard of. you need a pressure box to get any more power. :cool:
Limited to power production? :rolleyes: I have a pressure box and it doesn't do anything compared to the other chips.
I would also like to know what your truck dyno's.
Justin,
Good #'s. What fuel pump are you running right now?
Stage 2 Floort It CP3 supplied by a 150 FASS.
Increasing inlet pressure is on the list of future mods so I will probably have to get a 200gph unit or something else.
jwilliams3 said:
Wade have you dynoed yours with the mods?
no i have not, it's been very agrevating not knowing but some of the track runs suggest around 800hp, sometime this month i will have it all figured out---hopefully, i just dont have the time for my own truck :{
Justin,
you also have a stock cp3 :rolleyes:
there is a kit that i have that will allow you to adjust your fass150 on the fly from 25psi to like 75psi Oo.
