I put my truck on superflow's dyno on saturday and had very inconstant numbers. max power was 526hp 1062 tq at 2600 rpm. other trucks with tst box made more hp with single turbo and would rev to 3150 for max power. Boost never went past 38 psi. on the street, after the dyno 60+psi.
I called laserbob and had him set up dyno for some more testing. had runs from 536hp 1150 tq to 280 hp 500 tq. no run made power over 2800 rev.
I talked to mark chapple, from tst, he said that his box does not defuel at any given rpm, and he suggested that it may be torque management, the cummins ecm may defuel if it sees slippage at the transmission, or before it shifts, but didnt know.
Does any one know if the 48re trucks that have stand alone pcm (early 03) have defueling at 2700 rev?? or does this setup see sllipage and defuel to protect the trans??
-robert
-robert
