AK RAM said:Good news and bad news. The flash didn’t help it at all. The good news…
I had TST send me a used box with the twins program on it to try. Hooked up this box and the surge is gone. RPMs are as smooth as silk. The problem is, this box doesn’t feel very strong. 5/5 is suppose to be about max power with this program, but 5/5 feels weaker and less EGTs than 7/7 on the soft program. Don’t know what is going on there. 6/6 on the twins version doesn’t feel as strong, but EGTs are a little hotter than 7/7 on the soft program. Maybe it is just me.
Took the twins box off and put the soft box back on and RPM surge is back.
Don't quite know what to make of it, but still tinkering with it.
Funny, I had a talk one day with mark about wastegates and the way the TST fuels (based upon boost up to 35 psi)... Think about when the TST overpowers the wastegate, I can push like 10 psi past the factory wastgate... Well even the SLIGHTest lift of throttle would make the TST defuel (due to not enough fuel to pin the wastegate open) -- BUT when I set my wastegate at 30lbs, My surge was lessened and I would have to take the levels up higher before the surge came back
WELLLL... . With the twins program, fuel is all in by 12 psi --- SO, when the TST sees you lost boost down to 25, from 30. . IT does not care and still fuels 100% --But with the single program, it would see the loss, and then the TST WOULD defuel because now it is seeing less boost
Any thoughts?
