Finally got the truck up on the rollers again after the last few mods. Last run with only the Comp delivered 311 HP and low 800's Tq - I have since added 1. 6 injectors, a 4 inch exhaust - and the Smarty. Bottom line was, I gained a best of almost exactly 100 HP with 414 HP - and torque maxed out at 972.
The strange part (to me) was that on the 3 dyno runs I made, I use the Smarty on #8, and the comp on 3x3, 4x4, and 5x5 - and the HP on all three runs were nearly identical in HP - the 4x4 run edged out the others by about *one* HP, and about 3 HP was all that separated the lowest from the highest!
I really had expected a LITTLE more power difference between those settings!
I had wanted to try one run with the Smarty set back to stock programming and the Comp on 5x5 for a direct comparison with my last dyno session, and also to see what the Smarty was adding to the mix - but the dyno guys were working real hard at keeping the trucks moving, so I settled on the above 3 choices - truck was in 6th gear for all 3 runs, and it was a Dynojet dyno - and a NW Bombers event.
SO, I ended up with 414 HP, and 972 Tq - not too bad for the mods I have on the truck - and certainly all I plan in the way of power upgrades for the time being...
I post this purely for the benefit of others with similar mods - it sorta helps to compare notes and see how one truck measures up with a few others similarly modded.
