Dynoed Truck
Difference Between 2003 and 2nd Gen Maintenance
Fuel Odor
hey Jderbedrossian
On your dyno run was there any noticable increase in performance under 2000 rpm or is all the performance gains in the upper rpm range?
I only mention this because i've read where some other boxs ,that increase feul pressure only, don't do much under 2000 rpm.
dj
Originally posted by djbobo
hey Jderbedrossian
dj
Any answers for this question?
answer to question
fencebuilders
There is not much increase under 2000 rpm. I had asked PDQ about this when we first recieved our boxes. They told me that they were having problems with the truck idle when they made the power come in below 2000 rpm.
Brad
Intense and Fence Builder, I think intense is right about under 2000 rpm's, but I think the fuel only boxes (like edge) give you more power at low RPM's than a timing/pulse box.
Low end
I have had my box for more than a month now,
forshure does not have the low end that the ez has
ez would burnem off the line wont happen with the
vol box but up top weee haw
Not that I know much about the 03-04's but looking on the net and even at PDQ has the volumizer under Diablo Sport on there page. It appers the box is made by Diablo and sold by many.
Here is one place I found it... . and for less $$
New Edge
It sure looks like Edge is having issues with their new product. They will not say a word other than "its on its way" i have heard good things about the Edge folks but they are stretching things mighty thin. Not to mention they requested "Beta" testers a few weeks back on their web site. I took the time to respond/fill out the questionaire and i get no response,no acknowledgement,nothing. Far as im concerned they suck big in the communications department. :-{}
A friend has a Western Diesel box on his 03 HO and on the rollers it made 378hp on the high setting.
The truck will roast the 315's and it smokes ALOT.
So I'm assuming it's a fueling and timing box.
The first one he had set some codes off and wasn't that impressive. He sent that one back and the new one plugs into the crank sensor (i think) which the first one didn't.
I'm sure someone else makes the box for WD. Why isn't anyone running this box?
It seems to work pretty good.
I've got the BullyDog Adjustable Torque Dog (good one) on mine... this one is 3 stage switchable on the fly and is rated at Stock, 70 hp, and 140 hp accordingly. I guess BullyDog had some problems with them on some trucks so they're replacing those that had problems with a 90hp max box (the one they offer now)...
I've had good luck with mine so far (6k miles ago) and it RIPS! smokes too on the high setting!
