Engine/Transmission (1994 - 1998) DZ Hybrid Turbo or Water-Meth Injection/TurboMaster
Engine/Transmission (1998.5 - 2002) 98.5 HP question
I'm looking for a power increase but also, and more specifically, an EGT increase. Which of these do you think would benefit me most? Both will be put on eventually, but only can fund one at the time. Before I blocked off my wastegate today, I could bury the EGT gauge just a little after it shifted into lockup. Now of course I can't because I have to worry about burying my boost gauge. So I need a way to lower my boost (wastegate or bigger housing), I need cooler EGTs WOT, and I would like more power. What's it gonna be? What's your opinions?
Trever
Water injection will cool your EGTs enough to be safe. If you want, i would go to a different housing. See if you can find a 14cm housing with a larger wastegate. The more boost you build, the more heat you are going to create also. Correct wastegating can help out with the flow of the exhaust, EGTs, and power.
