E-Brake/EGT question
Ricksons : Wanted
oil temp gauge HELP!
Lordsman
On a Cummins E-brake by Jacobs; will there be an access port for post turbo EGT probe/T-couple as there are on other brands?
I have just bought Autometer gauges(thanks to all input on pictures post)and will also be installing an exhaust brake. I'm partial to the E-brake at this time. Thanks to all.
99 2500SLT,QC,4x4,6-spd,3. 5 lsd,LB,Camper group ,Rhino liner,Airlift 5000 airbags,Redline hitch,Tekonsha brake control,Diamomd plate bed rails,Dodge grill & splash guards.
LORDSMAN,I have the cummins E-brake and it does not have a port in it,I too am dissipointed,I think one can be drilled and tapped into it,just be sure you stay far enough down stream so you dont effect the valves operation, Kevin
No they don't have a factory hole for a thermocouple. If you decide to put the thermocouple there,be sure not to drill on the casting seam. Some folks said the casting can split from drilling on the seam.
-Mike
I e-mailed Jacobs about drilling the casting boss on the e-brake for a 1/8"NPT probe. They indicated that it was there for the purpose of installing a temperature probe. It will not void the warranty if properly done. Their e-mail address is Support/JacobsVECo. @JakeBrake
I removed my elbow to drill and tap it. I don't think the seam in a casting is a weak point. You can locate the hole anywhere that's convenient. I located mine just past the turbo outlet so it would be accessible. Like Kevin said, be sure it doesn't interfere with the flapper.
1996 Dodge 2500 4X4 SC, SLT, Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights.
[This message has been edited by radixr (edited 03-06-2001). ]
Thanks for the input. I think I'll still be installing the Jacobs E-bake. I'll find a way to go post turbo EGT. If any one has drilled out the housing for an EGT fitting let me know how it went. I will however be e-mailing them(jacobs) to get more info.
Lordsman-
Drilling the Jacobs E-Brake elbow is real easy. I didn't use the casting boss as my measurements were showing that the pyro would be extremely close to the butterfly valve and I didn't want to risk it touching (I used a VDO pyro which is 1/4" NPT). You can also make a practice run on the stock elbow after you remove it prior to taking on the E-Brake. Good luck,
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
