E-brake, I'm so screwed up!!!
Why not make your own dual-inlet plate, or even a triple?
Gasoline in Diesel
Ok folks, I want to buy an e-brake (Jacobs) but I'm going around in circles with p/n's.
Been reading all the threads on e-brakes and there seems to be many different part numbers going around for the 2001. Mopar p/n 050177008AA, Cummins p/n 3800791, etc.
Talk to Mopar-for-Less and they say p/n 82205577, they "think" for the 01.
Talked to Cummins today and they say p/n 3800780 brake with a 3800555 adapter. They never heard of 3800791.
Can anyone help me to unravel this mystery? I need a brake NOW! Thanks to all.
Ordered part number 82205577 from Mopar4less.com today. From what I hear, this is the correct part no. for the ETH and also backward compatible for a couple of years ($595 + 8. 00 shipping).
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT Plus, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Leather, Sliding Rear Window, etc.
"Diesel, it's not just for breakfast!"
I ordered part #82205577 for my '01 ETH 6 speed and have it installed. It is the right one and it is an easy install. Two tips; remove the bolts holding the fuel filter on and it will lay back towards the drivers side fender liner to get at the ECM, and when inserting the "red wire" into space 20 on the ECM be sure it goes in till the insulation is well into the hole. It took me several trys. Each one involving putting the fuel filter back on and trying the brake. Suddenly it just slipped in much farther than I had been able to get it in.
I orderred from a Dodge dealer in Va. Can't remember the name but the phone # is 1-800-559- 6698. The price was $540 plus $20 S & H to Oregon. It works very well.
Vaughn
Merryman, thanks for the confirmation on the part number. Also, it sounds like you got the best deal on the price, although I have been very happy with the customer service at mopar4less. By any chance, did you also tap the exhaust manifold during the install for a pyro?
David Dressler
I tapped the elbow 1st. Then did the selinoid, (remember to change the bit back to 7/16" for the exhaust!!) Then dropped the turbo and did the exhaust (both front & rear). Then finished the install. Did notcut the insulation back but "punched" the 4 holes in it after marking. Then drilled the mount holes.
Drop the filter (just the two bolt) and use a 'short" allen wrench to undo the ECM connector. Push out the plug (mine was red and the only plugged hole to the rear), inser the wire about 1"" or more (it does go in a looonng way) until it "clicks" into the hole. Try pulling it out (GENTLY) to ensure its "locked" in.
Just another 0. 015$ worth of info.
\\BF//
I downloaded the parts manual fromthe Cummins website. I too have been pricing the Jacobs E-brake. Below are the various numbers I came up with.
82204664 Mopar
05013776AA - Assembly group
05013778AA
05013779AA
05013774AA
05013766AA
05013764AA
05013784AA
3800482 Cummins
3800649 Assembly group
3800644
3800627
3945077
3870864
3800359
3800358
I e-mailed Mopar4less and this is what they responded with. Hope this is helpful.
e brake #82205577 runs $595. 00
