Doc, I'm supposedly certified on the "02" Cummins product. What does that mean? As far as I can tell it means they paid me to watch a couple virtual college CD Roms and answer enough of the test questions correctly to pass. Have I ever worked on one? Nope, not yet. Am I disgusted? You bet. I hope others,(R. E. Miller?) are getting more hands on training then me.
Heres what I remember from the CD Roms.
If an EGR valve gets stuck open or closed, first of all there will be a check engine light, as the valve has logic to tell the ECM what position its in, in relation to engine speed, throttle position etc. The valve also uses a motor for operation
Pretty much any check engine light will be in conjunction with a power derate.
Physical effects of an open valve would be low power, if there is not enough oxygen in the cylinders of course it won't run.
A stuck closed valve should run fine but low power due to the check engine light and derate.
I don't believe there are any oxygen sensors in the exhaust, if I remember right, the ECM adjusts everything based on algorithms of the current operating conditions, and assumes emissions are in spec.
Additional hardware includes EGR cooler, Egr valve, turbo speed sensor, Variable Geometry Turbo (VGT), EGR mixer in the air inlet.
(I'm going by memory so help me out guys, with things I missed. )
As with any new product, training usually ends up being done in the field on real problems, and if this new system is typical of others, the cause and effect of broken parts may not be what the factory tells us they will be. It seems there are always several new pages of troubleshooting advice a year or so after introduction.
I really don't think EGR is a big deal, its only a few more parts and once we understand better how they all interrelate troubleshooting should be pretty straight forward.
I'm more scared of Cats' ACERT technology, and the implications for me if EPA decides that is the way to go.
A Johnson
A Johnson
