E.G.T How hot is too hot?
Horsepower?
Edge products...
I just got my pyro and boost gauges today and plan to install them this week. My question is,how high can the egt's get before you are going to damage the turbo?Is 300 degree's the accepted temp. for shut down? Thanks
2001 3500 4x4 Q. C 6spd H. O Patriot Blue
Thanks Evan. Would that be prolonged running at 1300 or would the occassional short burst above that[say to beat that pesky F**D over the hill] do damage?
Mag. . when you see aluminum dripping out your exhust you have gone to far #ad
and the shut down # needs to be 300° or less remember that your oil will not cool as fast as the gauge showes the exhust temps. your turbo will cook the oil and coke up the oil.
[This message has been edited by willyslover (edited 02-05-2001). ]
If you saw a max of 1350 degrees during a run I wouldnt panic, but you dont want to see much higher than that number sustained. (this is pre-turbo)
99 QC. Sport,2WD 139"wb. auto,3:54 limited slip,all options except leather. autometer ultralite boost and trans. temp gauges,computech digital EGT moniter, K@N 14" cone filter,275HP. RV injectors,custom 4"exhaust, power edge EZ, DTT VB & TC, mopar performance deep transmission pan, mag hy-tech rear end cover, roll@lock bed cover,plus other cool stuff.
[This message has been edited by WAYNE (edited 02-06-2001). ]
