Details here: TDR Privileges
I'm about to put on a set of Procomp Xtreme Alloy 1869's with 315/75-16's on my truck. Is anyone else running these? They are 16X10's with -24mm offset and 4 1/2" back space. Will I eliminate my tire rub?
Lone Ram... The good news is the tires will not rub the control arms . . The bad news, with a 2" leveling kit in the front, the tires will dig into the rear part of the fender well, because of the rim off-set. I have the same tires, with 16x8 rims, and to had to pound the hell out of the fender well and cut 1/2 of the rubber splash guard out to clear. I probaby have 1/16 " clearance... . With 16x10's, you might not make it at all... You will need a 4" lift to clear. . If you drop down to a 305x70x16, you'll probably be "ok". Before purchasing, have them mount one tire to check clearance.
