Just thought I'd share this information that I found today to help the next guy that has this problem so that this is searchable. The easy entry seat feature stopped working for me last week even though it was turned on in the menu. Turns out that if you manually make the seat go all the way back while this feature is enabled, it cancels the function even though it is turned on and turning it off then back on does not fix it. Eg, cleaning the truck and moving the seat back out of the way.
To fix it you have first turn the feature OFF in the menu, then run the seat all the way back, then all the way forward, then all the way back again, then hit your preferred seat memory button and let it go to your set place. Now go into the menu and turn the feature back ON and it will work again.
Kind of a dumb kwirk if you ask me, but this fixes it.
