I am pretty sure I got this tip from Harvey Barlow on the TDR... Thanks!
Every time I have tried to drain the water from the fuel filter housing or changed the fuel filter, I ended up making a BIG mess on the garage floor.
I cut a 5/8" dia rubber hose approx 12" long, crawled under the truck on the clean garage floor and slipped the rubber hose over the clear plastic drain tube from the fuel filter housing.
I inserted the other end into a 1 gallon jug that was 3/4 full with used engine oil and then flipped the yellow drain valve.
Took the used oil to the recycle station.
No mess at all !! Not even one drip ...
Thanks HBarlow and TDR
