easy way to keep fog lights on with high beams
A/T temp sensor location
Oil filter spun loose
After studying the wiring schematic in the manual for a while I found that you can remove the fog light #2relay from the power disturabation box and make a 11/2" jumper with a male spade on each end one of which has to be as narrow as the relay spade and plug in to the #3 and #4 terminals from which the relay came from . The terminal numbers are on the bottom of the relay which should be the center two terminals,and then the fogs stay on even on high beam.
Is that true of all models with the factory fogs?
1999 3500 Cummins 5spd QC-SLT(RED), Fiberglass Bedcover, Autometer Boost Gauge,Lund Screen Front-RATTLE,RATTLE;STINK,STINK
1998 Durango 5. 2L Auto SLT 4X4,Loaded
Rockin' Down the Highway
For you all who have installed the kit from Mopar Parts, the relay is under the dash. Just unplug the wire that controls the relay from the hi-beam circuit. The relay is a normally closed relay and the hi-beam opens the relay where you don't get the fogs with the hi-beams on.
Bill
97 3500CC,Auto,4. 10LSD,All Options incl Leather,Pyro,Boost,Trans. Temp Gauges, PacBrake, 3 pos TC Lockup Switch, RPM 40Gal. Aux. Fuel Tank, Reese 20K Hitch, Highway Products Tool Box, 80% Towing 12,100lb. HitchhikerII 5'er. 2000 3500QC 6 Speed,4. 10LSD,SLT+ on Order since 9-23-99,"D-1" Order Status, St. Louis Plant, Ship Date: 11-30-99, As of 12-1 built, painted,installing trim,will ship today
Hey Bill, I've got a 99. Is the layout the same. I'm under the impression that all I have to do is disconnect that wire. Where under the dash is it located and if it applies, what color is the wire? TIA.
John
1999 Dodge Ram 3500 Quad Cab 5 spd; 4:10 LSD rear; Mag-Hytec diff. cover; Speedliner spray in bed-liner; Amsoil foam air filter; Smittybuilt step rails; JVC 12 disk CD system; Windows tinted; Manual transmission filter kit; Geno's EZ Drain oil pan plug; US Gear EGT and Boost gauges on a twin A pillar mount. Towing a 31 ft. NOMAD single slideout TT. Hoping Santa brings me a Horton fan.
Rammin' and Runnin', but not stepping on the rails
Not going to sit here and tell you your wrong, but on my Y2K I've had mine done since the day I owned it. I went to the fuse box under the hood and pulled the relay. I put a jumper between terminals 3 and 5. On my truck termanal 4 is blank. Who knows, they change them every model year.
Butch
2000 QC 4X4 24V 3500 4:10 All Options Auto Pac-Brake Blue Chip Box Banks Pillar Gauges B&D Valve Body Aux fuel/tool box combo Bright Box Geno's Garage Fender Trim Kit 1999 Excel 37' fifth, 1999 Concord LXI. Wife says I need to add "One Dodge Diesel Dog"
I followed ramman's directions and it works great. I have been wanting to do this for awile. Next up will be the Bright Box and some PIAAs.
98. 5 ISB 5 Speed 4x4 SWB Quad Cab K&N
I have a '96 truck. I jumped terminals #3 and #5 on Fog Lamp Relay #1 (according to the shop manual layout) to keep the fog lamps on with the high beams.
Dave Wist
