After studying the wiring schematic in the manual for a while I found that you can remove the fog light #2relay from the power disturabation box and make a 11/2" jumper with a male spade on each end one of which has to be as narrow as the relay spade and plug in to the #3 and #4 terminals from which the relay came from . The terminal numbers are on the bottom of the relay which should be the center two terminals,and then the fogs stay on even on high beam.
