I noticed on a handfull of occasions in the past few months my fuel pressure gauge would read 0 after a cold start. It usually would happen with colder weather. I finally had a chance to look at my truck yesterday. I checked the voltage at the lift pump and found 9 volts which would vary up and down by 1 volt at times. I know the lift pump goes from a 25% duty when the key is first turned on to 100% when the truck is running. Shouldn't I get a full 12 volts to the lift pump while its running? I can also see my fuel pressure vary a little. At times while I was testing(had my wife bump the starter) the voltage would read 2 volts for a second & then read the 9 volts with the lift pump responding accordingly. The lift pump relay is in the ECM & I'm thinking that is my problem. The lift pump is a couple of months old and is not running when I have the 0 fuel pressure. I don't want to rig something up to cure it(switch & relay), but I also want to ensure the injection pump will last. Anyone have an ECM they could part with that's reasonable? Anyone repaired this a different way? Suggestions are appreciated.
Oh Yeah,
The truck has 106k on it so warranty is not an option.
Oh Yeah,
