The Bilsteins are good shocks for awhile but die faster than anything else I've ran, wore out two sets of blue/yellows within 20k miles each then switched to KYB Monomax shocks. The KYBs have held up much better, they're a little stiffer to start with but so far considerably better shock
KYB Monomax Shock
Hi Vaughn,
I just replaced the shocks on my 2002 Durango with KYB Monomax. I love them, however, these were the hardest thing I have ever done to any vehicle as far as effort goes. Since they are monotube shocks that are charged to 360 psi, they don't compress when you are under the vehicle, even if you are the Hulk.
I had to jack up each corner and fully extend each corner, then:
On the fronts, I had to compress them with all of my weight and then tie strap them in the compressed length and then install them.
On the rears, I used a floor jack to compress the shock just enough to slide into the lower bracket.
BPITA to install, but very worth it...
I would love to get these for my 3rd gen, but after looking at the truck install compared to the Durango, I am not confident I would ever be able to get them installed.
The truck looks to be about 2x harder, especially the fronts. I can't even see the lower bolt on the PS of the truck. The rear lower brackets completely cover the lower hole like a skid plate , so a floor jack wouldn't work...
Any insights?
Thanks,
Louis
