Edge Attitude A Pillar mount
Transmission Slipping
2004.5 Dodge
I got the A pillar mount from Edge today and installed it.
Unfortunately the cable to the Juice is internally connected to the attitude and not removable.
It was a pain in the neck
If you want to install the mount do it while you are installing the juice to begine with
I just used a dremel and made the opening in the mount a little bigger. Does not effect the mounting in any way and you can feed the Attitude through with no problem.
JVolpe,
did you have a hrd time getting the attitude to stick to the velcro? I was gonna try to cut some of the channel for the wire away to see if the att fits better
New pillar mount for Attitude & analog gauges
This company has pillar mounts that replace the factory plastic, uses the same holes and is already matched to the color and grain of the factory plastic.
Not listed on their site is a mount for Attitude with 0, 1 or 2 analog gauge holes. Give em a call, I ordered mine this week, should arrive via UPS today.
http://www.dieselperformanceparts.com/cgi-bin/search.pl/dieselshop
Cmullen
Yes the supplied velcrow stip was not thick enough to stick good on each surface on then velcrow together. I have a large roll of industrial velcro(thicker) that I used. Did not have any problems with it after that.
Cmullen
I believe that I got it at a NAPA auto supply store. Mine is a roll 2" wide and 21' long. Been using that stuff on everything for the last year.
