EDGE Attitude, display only
Supplemental Hydrogen Fuel Source?
amsoil out--mileage up??
Hrumfelt,
Sounds like pretty damn good towing milage!
I only get about 11. 5 mpg when towing my 26ft, 6000lb TT (Keystone Bobcat). Now that is at 65-70 mph with some rolling hills, and my trailer is not real aerodynamic. I get about 17-18 mpg at 70mph not towing.
What kind of trailer are you pulling and how fast?
qzilla said:
Controller Features:
Stand Alone Operation
Will work on 95-06 Powerstrokes, 98-06 Cummins, 01-06 Duramax’s
Reads EGT, Boost, and Trans Temp with the option to read Fuel pressure fuel ... ... ... ... ... ... ... .....
I am sure there will be a bunch of questions and I will answer them as they come in.
I have a drawing I will post later, and actual pictures should be ready Fri, or Mon.
Wow, thats quite a mouth full - Any pics you can leak out?
The turbo timer really sounds nice :)
HRumfelt said:
Help I have purchased a 2003 Dodge 2500 commings truck. I put an Airaid air filter as K&N only had a kit. I have only been getting 16. 5 miles to gal;lon. I have changed the Dif to moble 1 synthetic and had my trans filter changed and new fluid. Which box Eadge tuner or Banks or which do you folks recommend for increase in fuel economy and to be able to increase HP for towing. I pull a small trailer 26 ft but it weighs about 7000 wet! My fuel econlmy goes down to 14. 5 to 15 miles per gallon when towing. Wht do you recommend?
Hey! You just hijacked a thread that qzilla was hijacking! :-laf
