Edge Attitude
2003 Auto transmission Problems
Who so far has had the rear axle completely replaced??? Me too!
Does any one know anything about this product? (Attitude Monitor)
The Power Edge Juice with the Attitude Monitor is a plug in module that installs in 45 minutes. Using the monitor you will have 6 power levels adjustable from stock to 120 horsepower. The monitor will also be able to display you exhaust temperatures, boost, and engine temp. You can also set the monitor to de-fuel at a certain exhaust temperatures. Comes with everything you need to install.
Is this a monitor that plugs directly into the ECU and does not require the conventional installation that gauges require?
Thanks Sam
The Attitude plugs into the Juice box. You have to have a probe in the exhaust man. for egt's. , which hooks to the Juice box. Then 12V, and good ground to the box. Then it has, if I remember correctly, three plugs to inj. , and 1 to the map. , that is all. Very easy hook up. The digital read out is real nice, has egt's, temp. of the juice box, (why, I don't know) and boost. You can set it for a warning when egt's get to a certain *, and also a hi boost warning. It also records the highest egt's, boost, and eng. rpm's.
I have ran it for about 28K mi. now, I really like it. Has real good low end, and mpg's are up 1 to 1 1/2. It has 6 settings, 0=stock, 1= best mileage, 2=towing, 3=driving, 4=drag race,and 5=Extreme. It smokes a little on 4 & 5, but not very much.
Hope this helps, and I hope, like the rest of you, its on the mkt. soon! I have not dyno'd it yet, so don't know what its putting out, but it comes on real strong on 4 & 5, and tows real good on 2 & 3.
Larry
