OK,,,,,,,,,,,,,,,,,,
On the injectors I would do the F1. 6 or F2. 0.
How are you going to fuel it when you upgrade? The lift pumps are marginal at best. FASS, RASP, ???? There is a thread on keeping the VP cool so the electronics do not heat cycle as badly and go bad in 50k miles and you replace the VP on your . 02.
You imply you are going to tap your pump wire. Are you going to "scotch-lok" it?, solder it?, Blue Chip Diesel has a replacement electronics bay cover with a set screw to tap the electronic board, which method?
There is one camp that thinks that bigger injectors are the way to go "more naturally" and only use the Comp as a boost fooler or for the "wire not tapped mode (40 hp)". That way you are not messing with the VP solenoids and timing and letting the VP "do its thing".
If I had it to do over I would go with larger EDM injectors (F2. 0) and EZ as a boost fooler.
If you set higher levels on the Comp the more stress you put on the VP (= $$$ later). Do really detail understand what you are doing with the VP timing solenoid and rotor diaphram when you tap the wire. You are your own warrantee station!
My . 02
Bob Weis
