Rumors as it that I'm getting an Edge Comp for xmass.
I'll get to use it on trip from TX to AZ over new year. The transmission does not have the DTT stuff in yet(Spring or early summer)
Should I hook up thr VP44 wire or not?
How much of a difference will it make?
What setting can I run it, without trashing the transmission?
I'll be towing my fifth wheel (8200 lbs dry weight) what setting should I put it on or just leave it off?
Should I increase line pressure?
I don't give a s**t about the warranty issues and I will be installing the boost elbow. To hook up the pump wire or not is more for avoiding temptation of using the power on the stock transmission, as I can't afford to trash it right now. If I can get power comparable to the EZ for now, without the pump taped that's what I'll do.
As always your input is appreciated.
Keep the pepcid handy,
Glenn
Glenn
