Edge Comp vs. Drag
Petron Oil?
Need opinions on 2wd suspension lift
Does anyone have any info on how much more power the Drag upgrade adds? I just got it done and my truck has a ton more power and alot more smoke now but I am wondering what the real gains in power are.
It seems as if the Drag has more power on setting 3 that the Comp did on 5x5
On 5x5 the Drag is too cool for words...
Bill
the drag box will continue to fuel past 2700 rpm. the standard comp box starts to defuel at 2700 rpm to control egts. the drag box will feel stronger after 2700 but should be the same until this point. if i am wrong somebody will correct me. :)
Propuller,
Thanks for the reply. From what I understand that used to be the only difference. Since then I have heard that it is a totally different program.
From what I am seeing while driving it seems to confirm that.
Bill
bill i just got off the phone with justin at edge & he said the only differance between the comp & the drag is that the drag continues to fuel to 3200 rpm & the comp cuts back at 2700. hope this help. have fun kurt.
