Engine/Transmission (1998.5 - 2002) Edge ez & DTT Valve Body
Will it hold up?
  • Trans will be ok
    Votes: 10 76.9%
  • Trans will not be ok
    Votes: 3 23.1%
  • Total voters
    13
Engine/Transmission (1998.5 - 2002) Oil pressure at guage
2nd Gen Non-Engine/Transmission Pyro Probe Location
We need more info,how much weight are you towing,is your towing in the mountains,or flats. what is your gear ratio?You need to answer these first,for most of the guys yes it will hold up,if you are within the 16K GCWR with 3. 54's,and 18,000 with 4. 10's.
IMO,you should be fine,as long as your transmission is in good shape now. You might want to ask a transmission expert like Bill K,what does he say?The 4. 10's are what will keep your trans alive with that GCWR.
