EDGE EZ WITH STOCK TC&VB SAFE???
Polished my new turbo (Piers HX35/14)
New Product, Edge Products A2
I never had a problem in the 25k miles I ran the stock transmission w/EZ. I didn't abused it either. One word of advise I would give you is to let the motor rev while towing, if you lug the motor that's when the transmission starts to #@$%!
I usually tow/haul in the 2200-2400 RPM range and this also helps keep EGT's in check.
Is the UNTAPPED COMP REALLY THE SAME AS THE EZ ????
They say even if you dont tap the fuel pump wire you can still take it out of stage 1 and increase the throtle responce but thats it.
I Think Im going with the comp and wait untill I upgrade my TC/VB before I do the tapping
I still want to be safe with an EZ style HP gain untill I upgrade the trany.
DM
Ez
DM
Yes it is
1 sub level is the same as level 1 on EZ
3 sub level is the same as level 2 on EZ
5 sub level is the same as level 3 on EZ
