watch the EGT's and stay away from the boost elbow that EZ provides.
LesStallings said:I just put mine on yesterday, so what I have is only initial reactions. My rig is also the 305/555, which I understand responds very well to the EZ (and others).
Read the latest TDR magazine. One reason I went with the EZ is that it was the only one tested that did not cause the common rail fuel relief valve to routinely open, something it was not designed to do. I've also heard others that tow or are interested in dependable power (not to be confused with potentially equipment breaking ultimate power) have had years of sucess with the EZ.
If you want to be King of the Hill, don't mind breaking parts, looking to upgrade turbos and transmissons anyway, maybe the EZ is not for you.
Again, I'm on Level 3. If I go to 4 or 5, I'm sure I can break stuff too.... I believe the TDR article points out that anything over a 40-60 HP gain is beyond the useful capability of the stock turbo.
It's a good article and I appreciate those that research and write articles that the membership can benefit from.
DLeno,first off I want to say very good research on HP boxes,and down loaders,very informative. What is your experience on the ramifier HP box,compared to others. Just curious,I will be installing the ramifier on my 2004 cummins 305/555 motor this weekend. Thanks for any info. coobieDLeno said:not me. I'll let others roll the dice on the pressure relief valve. Level 6 is secret because Edge made it so to avoid this problem.
JHardwick said:I didn't keep up with this thread, but just now scanned through it.
I bought my EZ in the spring of '03 and made one run with it on the factory #3 setting. I went instantly to #6 and stayed there for 10,000 miles or so. Since then I've ran #4 for probably 40,000 miles. #4 seems less peaky and more driveable than #6.
I do however have to watch EGT's from time to time. For the most part I don't pay much attention, but when I'm loaded on a 5% grade I do. I can still accelerate, but have to "drive by the gage".
I never installed the "boost elbow" and still run the factory wastegate with an aFe drop in, modified airbox and straight exhaust. I did pinch off the wastegate hose completely for awhile. I could hit 40PSI easily, but it ran hotter EGTs than using the stock wastegate (max of 30psi).
I'm pretty new to the turbo charged diesel, but pushing the stock charger beyond it's envelope is hard on the charger and creates additional heat ... ... ... from the little I know.
I still want the juice, LMAO. A little timing and a little pressure would be just what the Dr ordered, that should conservatively get me to 425 at the wheels without blowing that damn poppit.
editedmax towing is around 15,000lbs, although I've towed more
