I need some quick help. I have read 15 pages of search results on the Edge and still haven't located exactly what I am looking for.
I am considering installing an Edge EZ on an otherwise mostly stock truck. (see signature) My questions are as follows:
1. Is this box okay to add without guages?
2. I have been told that the EZ has an audible warning for high EGTs. Is this true?
3. Does the EZ tap the pump wire(s)?
4. I have heard that installing boxes that boost the fuel pressure may wipe out the VP 44. Is the EZ a box that may do that?
5. Should this box be installed before there is a fuel pressure guage on the truck?
6. Should the lift pump be checked first?
7. Will the stock clutch hold?
Are there any other things I should consider before installing an EZ. I know you got to pay if you want to play I am just rying to understand how much I may be signing on for. The truck has about 84,000 miles on it with the stock clutch. When fully loaded, I have a gross combined weight between 18,000 and 19,000 pounds.
Thanks for any and all input.
