Edge HOT Update......what to excpect?
Wheres the EBCM?
Changing Rear End Ratio or OD Gear in G56
I just sent my Edge Juice w/ Attitude in to get the HOT update. I couldn't really find exact numbers on what it is supposed to do, I just knew I needed it. :-laf Anybody know exactly how much more power it gives?
Level 1-4 on the HOT Juice/Attitude is the same as 2-5 on the standard Juice/Attitude. Level 5 suppose to be 180hp/440torque. Dyno on mine showed pretty close to that with an EZ stacked. That is with FASS, and SPS66 turbo. I agree that with stock turbo you probably will not get near that.
I think you can expect the transmission to grenade, especially if it's a 48re. I've had a basic Juice/ Attitude on my truck for about 23K miles. I've got 30K and I think my 48re is on it's way out?? I don't blame D/C as I added the box, and I like to run on settings 2-3 a lot, and occasionally will run it on #5 here and there. The result is now every time the truck goes into lock/up in 4th I am registering approximately 2-3% slip regularly. I used to only get it to register 2-4% when running on #5 and hard.
-Ryan
I've installed three of them, two on autos and one on a G56 and I am very impressed they all run neck and neck with my set-up but with my smaller towing Jammer4's. Egt's not very bad at all, but them again I own a 2nd gen that will see 1600*. I highly recomend it. Just as strong on top end as a Crazy Larry but has a better bottom end.
Enjoy, Jared
-Ryan
I don't believe in automatics sorry. G56 here :D
